Chris Townsend: The Beo remote app used in my case on an Ipad mini, although fairly simple works very well.
I bought an iPad mini for the purpose of controlling my content....then realised after a week it's easier using the Beo4. iPad Mini is now used in the office. Beo remote app is decent though, but still easier to use everything with the Beo4.
Chris Townsend: The sound is frankly is in a different league. Great strength and clearer vocals, with lots of available bass from such a thin cabinet.
Yes, it's definitely a lot better than a standalone BV10. I didn't think it was hugely better than a BV10-46 with BL11 though? Definitely not in the BL7.2 league and no way near BL7.4+BL9s which I used to own with my BV7. That was the ultimate experience for me as the BL7.4 really enhanced voice, whilst the BL9s made movie-watching feel like you were in the cinema.
Chris Townsend: It is shorter than a 10 on a pedestal stand making it notably smaller.
Definitely agree there. Feels much smaller....which is a reason why I still think I should have bought the 55", in hindsight. A mate's first impression was that I'd downgraded to the 40", such is the size difference.
Used to it now though. I prefer the size of the BV11-46. Doesn't overwhelm the room. Shame there's no orange fret though.
Chris Townsend: Same thing with a black fret but a whole less more unwanted. Now sitting next to a lamp to see how it deals with a brighter room, the speakers are very visible. The black fret isn't a good choice. Back to red it is.
Yep, that's annoying - the blue fret is the worst for that (see through speakers). On a morning, when this room fills with sunlight, you can clearly see the speakers under the fret. Strangely, the red fret is better and, of course, the black fret covers any sign of the speakers.
Oddly though, the BV10 frets were far better in this perspective (not as see-through).
Chris - turn on "Cuckoo" on BBC1 HD right now (Tuesday, 11pm). Absolutely stunning on the BV11. No idea why. It's a flawless picture, lots of skin tone, which is rendered perfectly on the BV11. Not a great programme, but just does wonders for the BV11!
Chris Townsend: The game mode is a joke and they would have done themselves and me a favour by not even bothering. The 10-46 automatically changed over and was superb!
In what way is it a joke? I've yet to actually play a game on my BV11, even though the PS3 is connected. The BV10-46 (or BV7 for that matter) was fine for gaming. Why is the BV11 any different?
Brand spanking new 11-46 in black with red fret and motorised stand ordered today.
If my kids are reading this in the future as an archive and your now all grown up and wandering where your inheritance is, it's in Struer, Denmark.
BV11-55 too large for your home? I started to look at the BV11-46 but the BV11-55 was just another viewing experience. And the sound is a bit fuller on the BV11-55...
BV11-55, BS9000, BL1, BL19, Transmitter 1, Beo4, Beocom 6000, BeoTalk1 200, Sennheiser HD600, McIntosh MHA100
Chris Townsend:Yes too big for my current home, and yes I did look at moving into a bigger one. The 11-55 also starts to get within 7-55 range and I just can't warrant that sort of extra money at the moment.
You are so right to get the BV that fits the space as I have often seen huge tv's engulfing a room. i am with you on 11-55 /7-55 price issue.
Enjoy your new BV
Tonker:Brand spanking new 11-46 in black with red fret and motorised stand ordered today.
Thanks so much for sharing your experiences of 11-46.
You've encouraged me (1) to stop lurking on this forum and to register as a member, and (2) to consider ordering an 11-40 or 11-46 myself. I loved your comment about inheritance...
Do you happen to know whether the TV's iplayer includes BBC radio iplayer? I've searched online and can't find any info about this.
Andrew
Thanks for these suggestions.
-I'm now wondering whether, if the TV won't get radio iplayer, I can send it from my Galaxy SIII which has an iplayer app.
But I never believe anything until I've tried.
It's the hope I can't stand (Michael Frayn/John Cleese..)
ded6ajd: Do you happen to know whether the TV's iplayer includes BBC radio iplayer? I
Sadly, no, it does not. Just checked. TV only.
I never use the iPlayer app as, without a HD in the BV11, you can't download content. Easier to use iPlayer catch-up on the Sky box!
Chris Townsend:There must be an Android device you can plug in to send media to.
You don't need one, same as you don't "need" and Apple TV to stream from iOS.
the TV is DLNA compliant, same as the V1. See below from bv11 tech specs
BeoVision 11 works as a DMP (Digital Media Player), which means that it can play content from other DLNA compatible devices, including a BeoSound 5.
http://www.ekoob.com/6-android-apps-for-airplay-dlna-11510/
Thanks very much for this info.
But I am now puzzled by a reply I've had from Mikkel Pedersen Customer Service (Denmark), who finally got back to me about the same question after i'd given up on them.
I was told that BV 11 did sport the radio iplayer.
Could you both be right? Could there have been an update of the iplayer even after only a few months?
Andrew (obsessively and apologetically)
Hi Andrew,
I've just taken a look at iPlayer on the bv11 and b&o customer service are correct - to the bottom left of the main menu you can select between TV and Radio.
Hope that helps!
sgc
sgc: I've just taken a look at iPlayer on the bv11 and b&o customer service are correct - to the bottom left of the main menu you can select between TV and Radio.
Sgc, you're correct, there's a radio 'switch' on the interface which I didn't notice. To be fair, I never use the iPlayer app on the BV11 as it's far easier via Sky (as you can download and store TV programmes for later viewing). So, yes, it appears you can stream radio or listen to previous radio shows, via the BV11.
Shame there's only one single catch-up app though. Feels a bit embarrassing even discussing it. Sky have added Sky, BBC, UTV, Channel 4, Channel 5 and other catch-up apps to Sky boxes. With our BV11/V1s, we're stuck with just the BBC.
Well i eagerly await my 11, BUT yesterday i went into my local Fenwick and saw the LG 4K 85 inch(i think) TV for £20,000. Price aside, even close up this technology is very very impressive. From 20 feet away its still impressive and perfectly suited for enormous screens.
Thanks both to you and moxxey - lots of really helpful people on this forum.
For me, it's a point in favour of BV11. I've a Panasonic device that does radio iplayer - the trouble is that it can't do it while it's recording stuff from freeview onto its hard disk - this is sometimes quite irritating. With the BV11 having its own access I could get round this.
Chris Townsend: Well i eagerly await my 11, BUT yesterday i went into my local Fenwick and saw the LG 4K 85 inch(i think) TV for £20,000. Price aside, even close up this technology is very very impressive. From 20 feet away its still impressive and perfectly suited for enormous screens.
I still think B&O will push on and release updated panels later this year. The advantage of 4K is you get twice as many pixels in the same area, so the picture quality should be much improved (pixel density is higher). I can imagine upscaled 1080p Blu-ray will look impressive on a 4K panel.
At this rate, I'll be upgrading my TV once a year, not once every three years :)
moxxey: I can imagine upscaled 1080p Blu-ray will look impressive on a 4K panel.
Just like your standard definition TV broadcasts look impressive on the full-hd LCD screens.... ?
I don't think so....
In fact, an older Pioneer Plasma does a better Job on this than most LCD from today.
It is interesting to see how an industry improves products step by step.Rember the first flat Screens (not just BV7-32), the Picture was worse than the CRT Picture!A side effect will be more bandwith (for online movie rental), too.Best regardsRalf
PS: For me 4K is interesting as soon as there is enough content on TV (Sky).
kallasr: Just like your standard definition TV broadcasts look impressive on the full-hd LCD screens.... ? I don't think so....
I should have remarked that others have seen upscaled Blu-ray's on a 4K screen and said they are very impressive.
You need to remember that Blu-ray has, in many instances, the most flawless image you can find. For this reason, it's not going to quite the same as upscaling a SD TV broadcast. Indeed, I stopped buying Blu-rays at one point, as upscaled SD DVDs looked decent on my BV10-46. Why? As the source material was already of a high quality.
Remember that SD and HD TV broadcasts are heavily compressed. HD via Sky can be mixed at best as Sky has halved the bandwidth for certain HD channels.
Blu-ray HD 1080p images are uncompressed, thus the source is of far better quality before you upscale. It's not the same at all. I wouldn't be surprised if an uncompressed Blu-ray upscaled 1080p picture isn't better or as good compared to a compressed 4K TV broadcast (if Sky can justify the bandwidth for 4K broadcasting).
kallasr:Just like your standard definition TV broadcasts look impressive on the full-hd LCD screens.... ?I don't think so....In fact, an older Pioneer Plasma does a better Job on this than most LCD from today.It is interesting to see how an industry improves products step by step. Rember the first flat Screens (not just BV7-32), the Picture was worse than the CRT Picture! A side effect will be more bandwith (for online movie rental), too. Best regards RalfPS: For me 4K is interesting as soon as there is enough content on TV (Sky).Beosound 9000 on floor stand, Beo 4 DTV, Beolab 4000, Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black, Beolink 1000, F1000 (3 cubes), Beovox 5000 (flat panel), Pioneer AVR VSX-LX60 with Beolab 8000 (Fronts), Beolab 4000 with small brackets (Centers) and Beovox CX100 (Rears - using a Teufel Rearstation 4 for wireless connection) and a KEF PSW2500 active subwoofer.
Chris Townsend:I like most of the public find plasma ghastly and unpleasant. There are very few I have ever seen that come anywhere close to say a Beovision 7-55.
That's just not true! I know you've continually expressed a preference for LCD but until the BV7-55 took over the roost from Plasma (if indeed it has) then the best picture was always to be found with the latest and best Plasma models (generally Panasonic after Pioneer quit).
The "public" has been led to believe that LCD was better by the manufacturers, primarily because it was cheaper and ever easier to manufacture.
Ban boring signatures!
Panasonic is now starting wo wind down production of Plasma TV as LCD is now out selling Plasma and is now too costly for them!
B&O started out by selling plasma only but had to give in to demand for LCD. People wanted LCD's, they'd been told they're the future!
I'm not sure the 7-55 sells by the truckload either!
Anyhoo - an interesting overview HERE on 4K, UltraHD etc. It seems, as ever, that the new generation of 4K TV's are just a stepping stone to somewhere else (which will follow shortly after no doubt). There also seems to be a feeling that an increase in frame rate would give a bigger picture quality improvement than the pixel density increase only. The advice seems to be don't be an early adopter.
Puncher: That's just not true! I know you've continually expressed a preference for LCD but until the BV7-55 took over the roost from Plasma (if indeed it has) then the best picture was always to be found with the latest and best Plasma models (generally Panasonic after Pioneer quit).
The BV12-65 has, for me at least, the best picture in the range for general viewing. Deep colours, smoother picture (LCDs can be very sharp, which some users prefer) and this really suits watching a movie. However, a plasma picture isn't great for watching sport. It smooths grass for for example. My dealer had the same Wimbledon match running on the BV12-65 next to the BV7-55. The picture was far better on the 7-55, due to the way the plasma rendered the grass.
Sadly for me, I watch a lot of sport.
