Weird idea, someone will probably want to slap me, but in my search to add a bit of amplification to my Beovox 5000 flat panel speakers, i wondered if you could run 2 amps alongside the beosound 3000 and the speakers. Bi-amping??? I already use one MCL amp to power both of them, the more I type the sillier it sounds...
No way - you can't 'bi-amp' the 5000's.
And - please - why would you?
One MCL-P is enough.....or the original 5000-LAB's
Then you'd have one for each
Millemissen: No way - you can't 'bi-amp' the 5000's. And - please - why would you? One MCL-P is enough.....or the original 5000-LAB's Then you'd have one for each MM
thought so, one of those crazy ideas one has from time to time, thanks for bringing me to my senses!!! Beomaster 6000 me thinks...thanks
