Are you searching analog channels? in Australia the analog signal is switched off and the TV needs a digital tuner. Some 7-32 don't have a digital tuner at all, but can always connect a set top box..
with the tv on, you press 0+0+menu+menu+go.
then choose tv-tuner.
Then there are four places where you can change the numbers, two are called "low, and two are called "high".
The two "low" I put to 49. (press "0" and it will change it automatically to the lowest posible which is around 49)
The two "high" I put to 860. (press "999" and it will change to the highest which is around 860)
Please write down the current settings before change them, in case you need to revert them.
(Sorry that I don´t have the exact names of the places you should change the numbers, but I don´t have the tv-set avaliable to chack atm, If you need more assistance just tell me, and I will check it later)
Keep me updated if it fixes you problem :)
