4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
I had a Sony BRP a while ago.
It was quite easy to control with the joystick, since the Sony menu's generally are pretty much up/down, right/left.
Good morning,
I use the PS3 Logitech PUC control for my BV7 Mk3 and that works perfectly. You need the PS3 Logitech IR to Bluetooth converter and an IR emitter. You connect the IR emitter to your Beovision and tape its emitting diode to the Logitech converter. You pair the Logitech with the PS3 after and its done.
I never had any problems with this configuration and I use the PS3 almost every day as a media and Blu-Ray player.
The RE-BL converter is an other possibility but much more expensive.
Good luck,
Jean
Good afternoon,
I use the Beo4 with the Logitech adapter: The BV7 receives the IR command from the Beo4 and transmits the Logitech codes using the PUC entry PS3 Logitech using an IR emitter. No need for a Logitech remote.
Best regards,
