Sonos and Beoplay V1 (just to be sure)
matbkk
Posts 43
matbkk Posted: Mon, Dec 8 2014 10:41 AM
Dear All,
I know that there is a lot of post talking about Sonos and BV1 but I just want to be sure before buying :
- all I need is the Sonos Connect and a Coax Cable ?
- then I can select the AV source with no picture ?
Mat
jans
Belgium
Posts 394
jans replied on Mon, Dec 8 2014 11:08 AM
Mat
That is correct. However you will have a delay compared to your other Sonos devices.
That is the reason why I have this setup but rarely use it. I have both the V1 and Sonos connected to a Powerlink switch. Works perfectly
Jan
matbkk
Posts 43
matbkk replied on Mon, Dec 8 2014 11:18 AM
Hi Jans,
Thanks for your reply. Actually it is another $300 and if the system is not perfect it does not worth it.
I have deezer already on the BV1. If I find a way to implement Soundcloud I will be good.
 Thanks for making me saving money, I owe you a beer Big Smile
Mat
Page 1 of 1 (3 items) | RSS
