Dear members,
I just got a new MMC 20 EN-R sealed in the original box. What does the R stand for? Does anybody know? How much is a new MMC 20 EN approximately worth?
Thanks!
Kai
The only difference from the normal to the -R models is the packaging.The -R models were in smaller boxes, containing no tools, certificates or instructions.You could consider the -R models spare parts rather than a product itself.
MMC1 was not available in -R version.
The -R is not printed on the cartridge.
Thanks Dave and Martin. Yes, it is a small box and only the brush is included. Also, the plastic protection around the needle is not in place. Other than that it looks like a normal MMC 20 EN.
Greetings,
