BEOGRAM 5005/5921
brianpowell
Posts 7
brianpowell Posted: Tue, Dec 9 2014 11:53 AM
I have had a Beogram 5005/5921 [serial no 3250104] since new, it is only used occasionally, but has now stopped working altogether! The arm doesn't move across the record, the turntable does not turn, and I can hear a click click click as though an electronic switch is try to start the platter and tone arm.
Do you know whether they fairly easy to open up and have a look? Or could you send me a link? Might it be drive bands, and if so does anybody know where they can be purchased? Many thanks.
DMacri
United States
Posts 881
DMacri replied on Sun, Dec 14 2014 11:32 AM
It's easy to check the drive belts. Just lift off the platter and plastic sub platter. You should be able to see the drive belt for the platter starting on the left, and the drive for the tone arm in the rear. You can PM Martin "Dillen" on this forum for the correct belts.
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
Page 1 of 1 (2 items) | RSS
