Beogram 4500 CD Player
Professor David A Flynn JP
Belfast, Northern Ireland
Posts 116
Professor David A Flynn JP Posted: Mon, Apr 14 2014 2:35 PM
Folks - have started a friend of mine on the B & O bug and he has just bought a 4500 CD Player - working great, except on some occasions the door will not open fully and sticks a bit - anyone suggest a remedy to fix this problem.
Many thanks - David
Sad
Professor David A Flynn JP LM
Big Smile
Orava
Finland
Posts 991
Orava replied on Tue, Apr 15 2014 8:44 AM
Mechanical problem. I dont member if it has belt or not, but change it if there is one. Otherwise cleaning chekcing gears ect will probably help. B&O uses also damping grease in door/lid mechs, dont mistake to replace it with normal vaseline.
Posts 116
Thanks a lot for this.  My mate asks can he spray the sliders (both sides) lightly with WD40 fluid?  He is not technology minded and I think that he is scared of opening up the system as he is not conversant with hi fi equipment.
Many thanks
David
Big Smile
Orava
Finland
Posts 991
Orava replied on Tue, Apr 15 2014 10:23 AM
No, not a good idea. If there is belt, it will loose grip totally. And it is not designed to be lubricated.
Posts 116
Orava
Thanks for this and I will let him know today.  I will get him to download the specifications details from the website.  I will suggest that he takes it into B&O shop Belfast.
Many thanks
David
Big Smile
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
It definitely has a belt and you can get a new one from member Dillen
Regards Graham
Posts 116
Thanks Graham I will let him know that this is the fault.
David
Big Smile
Weebyx
Denmark
Posts 1,213
Weebyx replied on Tue, Dec 16 2014 8:04 AM
Did he get this fixed ?
It is only the right guide that is motorised, the left is only a "dymmy" that act's as guide for the lid. When I have had problems with 4500/3500 lids, I simply take off the lid and the cover, and dissasmbles the gear mechanism totally, cleans it all, re-assemble / re-grease(with the correct white B&O lubicant), 99% of the times, the rubber belt also just needs a good clean in warm water and some dish-washing fluid, and then dried with a dry cloth.
Just make a notice on how the gear mechanism is assembled before just dissasemble. Take pictures, and remember where the 2 small washers goes :)
After this cleaning of the gears, the unit always is much smoother and less noisy..
It is not difficult if you just use patience and note where things goes.
/Weebyx
Page 1 of 1 (8 items) | RSS
