Exploring the depths of the internet, you can read things like this:
"Meanwhile, Philips Android-powered Smart TV will be the first TV to get Spotify Connect certification, again all controlled by a smartphone or tablet. Spotify says more TV brands are in the pipeline."
Are the newer BV's in the pipeline?
Would be perfect to be able to 'wake up' your BV to play along just by pushing the entry in the Spotify Connect app.
Spotify Connect would be so much appreciated!
Beovision Eclipse gen2 (GX) w/ floorstand, Beolab 14.2, 4 speaker Shape and ATV4/Chromecast.
Beoplay A9mk4 GVA, Beosound 1 GVA, H2, H3, H8, E6, Beoplay EQ
A premium service:
Mac
Windows
iPhone
iPad
Android
Aussie Michael:What actually is spotify connect ?
Another explanation could be:
The Connect version of Spotify makes it possible to adress and control a Spotify installation (on a Pc/Mac or on a Spotify Connect enabled device) from the Spotify app on a mobile device.
Means: you choose what to listen to in the app, send this request to the 'device' - the device requires what you want to hear from the Spotify server and starts the playback. The mobile device is 'only' remote control, and might be turned off - if wished for - during playback of the playlist/album.
Compared to regular Spotify playback, you can now adress different enabled devices - you can choose from where the music should play: kitchen, livingroom, bath etc. - or from the mobile device. You don't have to rely on AirPlay to stream Spotify - also non-iDevices can initiate the stream.
Could you - please - explain that in details?
You probably have a Mac connected to and assigned to DTV on the BV7?
'AV-DTV'
@leonsgonewild.
Quite an expensive way of getting Spotify on a B&O
And - I don't let Spotify choose what to play - I choose what to play...
....which is easier from the app on my iPad.
Makes things of course a bit more complicated.
I am an album listener - not a playlist-listener.
The cool thing about Spotify Connect is, that you (from the Spotify interface) can choose where to play your music. But - again - if you only have one 'place' to play to, you won't benefit from that.
I am aware of the 'controlling thing' - I do this sometimes, when I am sitting at my Mac Mini and listen to music via Spotify, and have my iPad at hand.
You are using Spotify Connect in that case too - the Mac-app has been updated for this recently.
Still - for a newcomer to Spotify, it's an expensive way of getting 'connected'.
There are cheaper ways - watch out for a new thread from me in the next days (I am working on it)
The Avant YouTube App can be controlled through the iPhone YouTube app. The (iPhone ) App automatically detects the Avant and plays the video selected on the iPhone on the Avant. This is how I expected the Spotify App to work. I was also disappointed to find that the Radio function is not available on the Avant.It appears only the music systems have full functionality.
https://support.spotify.com/uk/problems/#!/article/bang-olufsen
Tim
What I meant is that it is only possible to set the standard speakers for DTV to Speaker 1, Speaker 3, or Speaker 5.
So when i press DTV I can´t have it to start in Speaker 2 (since DTV is a video source, not an audio source).
If I press AV-DTV, my Beomaster will play the sound from the tv (which doesn´t work since it is a digital source, and I don´t have any speaker connected to it.
