Hi all,
I recently got the Beomaster 3000-2 from my uncle, which he said was working almost perfectly, he told me that the FM doesn't work though.
I recently have had it on the floor, ready to be moved to the shelf. I have tested before moving and everything. After i have placed it, and plugged it in, I turned it on and it gave a weird noise from it and now it won't come on at all. The speakers are connected with "muffers" (That's what it's called in danish) Check the image to see what i mean.
Thanks.
-Skashe
