hi,
My Beocenter 9500 has a problem with Tape.
I opened the unit and replaced the 3 belts ( well not the original ones but some that fitted well).
When I try to play any tape it makes a clicking noise( the actuator/solenoid is engaging and then disengaging).
The motor turns .....
I wonder what the problem could be?
Thanks in advance
