Beotime Battery replacement
Simonbeo
Posts 1,451
Simonbeo Posted: Mon, Dec 22 2014 4:44 PM
Time to replace the batteries on the Beotime and I removed the end cap with the key and took the battery tray out . As I realised I had no batteries I put the tray back in without any . Now it's difficult to get the tray out. Anybody else found this or do I just lever it out without doing any damage ?
thanks
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Mon, Dec 22 2014 4:58 PM
Now that you say it, yes it was hard to put the little black plastic tray back again.
I just pushed "hard" and everything is fine (done it three times in four years).
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Mon, Dec 22 2014 4:59 PM
It was hard to push it back and to pull it out also !
olvisab
Posts 1,391
olvisab replied on Mon, Dec 22 2014 5:01 PM
BeoGreg:
+ 1
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Simonbeo
Posts 1,451
Simonbeo replied on Mon, Dec 22 2014 5:07 PM
Reassuring then, as it seems difficult without the batteries. It might be worth a bit of pressure getting it out ?
valve1
The south of France and occasionally Dublin Ireland
Posts 1,502
valve1 replied on Tue, Dec 23 2014 9:53 AM
Its a tight fit for sure. I found it harder to get back in than out.
Guess you will just have to tease it out.  When inserting the battery pack push gently until it resists then pull it back a little bit and turn it and try again.
Simonbeo
Posts 1,451
Simonbeo replied on Tue, Dec 23 2014 11:28 AM
Yes. I seriously thought I was going to break the battery holder pushing it in but it was a bit easier when I decoded the orientation diagram .
Page 1 of 1 (7 items) | RSS
