Beogram 4002 tonearm lifts part way through LP
tenelson
Posts 2
tenelson Posted: Fri, Dec 19 2014 1:48 AM
I'm working on getting a Beogram 4002 functioning, following a period where it has been unused for a number of years. A record will play, and I've adjusted tracking as in this nice tutorial. However, I have been unable to get through an entire side of an LP...the tonearm always rises. The point at which it rises seems random. How can I fix this?
Steffen
Denmark
Posts 1,408
Steffen replied on Fri, Dec 19 2014 4:59 PM
Welcome to Beoworld. I can not help you with the specific issue. But I can show you where you may find an answer. There have been quite many threads about the 4000 series. Try this - or the Workbench forum:
http://archivedforum2.beoworld.org/forums/27.aspx
Dave Farr
France
Posts 2,283
Dave Farr replied on Fri, Dec 19 2014 6:11 PM
Welcome indeed.  Check out www.condoraudio.com which is operated by a Beoworld member with masses of experience with this series.  There is a really good link to a restoration of one of these BG's which you may find useful.  Apart from that, Silver and Gold members have access to all of the service manuals.
Dave.
tenelson
Posts 2
After some thought, I've determined that the yellow tonearm lifting solenoid has an intermittent short, which causes the tonearm to lift.
I tested this by shorting the two terminals during play, which recreates the problem.
The coil overheated and started smoking when I first got it running due to a problem with a broken plastic piece on the switch that switches the solenoid voltage from ~21v to ~3v. I thought all was well, but I think now that some of the magnet wire enamel on the solenoid coil melted, which causes a short when it heats up slightly.
I bought some magnet wire to rewind the coil, but I don't understand how to remove the coil from the u-shaped bracket in which it is retained. So...has anyone done this? Or, alternatively, does anyone have one of these solenoids they can sell me from a junked Beogram 4002 or similar?
Thanks!
tournedos
Finland
Posts 7,357
The plastic switch arm end failing off and subsequently the solenoid melting is a well known problem. I believe it was joeyboygolf who rewound a burned solenoid  in his BG6000, you might try searching for the old thread.
--mika
Page 1 of 1 (5 items) | RSS
