I recently purchased a little device that plugs into the 30 pin port on the BeoSound 8 (not the A8, just the older model) and recieves the an audio stream via bluetooth. this works fine on all the other docks in our house, from the Bose Sound Dock to the little alarm click in the bedroom. However it does not work on the BS8. i have relised that this is due to the fact that when you plug it in, unlike when you plug in a ipod/iPhone, it dosent light up with he green light which meas its on. The volume and track skip lights still work, but it dosent light up green, even if you press/hold the center button, turn it of and on at the wall or anything. is there anyway to manualy turn the dock on, so the sound will play. the device still works and recieves audio, but wont play it out loud cause the dock wont turrn on...? any help woul be apreciated. :)
And Merry Christmas!
-Cameron
