Beovision 6 Type 9250 Update the PUC List
Imperator1000
Posts 19
Imperator1000 Posted: Fri, Jan 16 2015 3:24 PM
Hello,
I have a Beovision 6 type 9250 (the first one). SO the PUC List is from 2003. Now I want to use a DVB-T Receiver from Skymaster (DT 500) and later the Technisat Digipal 2. How can I upgrade the PUC List because there is no possibility to connect the screen to a computer. The only connection is the Beolink and systemlink. The dealer wants to have 100€ for updating the list.
On the homepage of skymaster is the information they use the ir-code 0656 and 1165.
The picture shows a few of the supported receivers.
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Jan 16 2015 4:03 PM
It can only be done by a dealer because effectively it's a software update.  Perhaps ask if he can drop the price - especially if you take the TV to his premises.
Make sure that you 'future proof' the TV by adding all the STBs that you can think you may use in the future!
Imperator1000
Posts 19
Why I don't get this software from the B&O page? It must be possible to do it self.
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Jan 16 2015 6:30 PM
Only the latest B&O TVs (BV11, Avant etc) allow you to download the codes for new set top boxes.
I had mine reprogrammed for £25, but that was from a 'second life' B&O dealer from whom I was buying the TV.
RaMaBo
near Munich
Posts 626
RaMaBo replied on Mon, Jan 19 2015 11:36 AM
you can try the TEC. Digital PK for the Technisat Digipal, this might work because TEC. is the abbreviation for Technisat in the PUC / STB List.
Ralph-Marcus
Imperator1000
Posts 19
Now I have the Digipal 2 and it works.
Please select "TEC Digital PK" as your Receiver.
Now everything is fine.
Page 1 of 1 (6 items) | RSS
