5.1 with bv5
bramble
Posts 397
bramble Posted: Tue, Dec 30 2014 5:23 PM
Hello,
This could be a simple fix!!! But , here we go [:\'(]
Bv5 with 5.1 set up, in menu I can set front left,right and rear speakers with no issue
It's only when you go to set centre I.e bv5 I can't seem to increase or decrease the setting it remains a at 0, Is there a way of adjusting this level from . To allow it to be modified
Thanks for any helpBig Smile
Beovision 7 40 mk 5 ,beovision 6x3,   beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2,  5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
olvisab
Posts 1,391
olvisab replied on Tue, Dec 30 2014 5:50 PM
Hi
I had the same issue if I quite remember with my previous 7 40.
The only way for me to modify the sound coming from the center was to lower or increase the sound of the front speakers. That's stupid but it works.
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Millemissen
Flensborg, Denmark
Posts 14,680
The center channel is the 'reference channel'.
bramble
Posts 397
bramble replied on Tue, Dec 30 2014 6:06 PM
Many thanks , will give it a go.......
Page 1 of 1 (4 items) | RSS
