Hello everyone and happy new year, a question to the forum.
I want to give to my BeoSystem 7000 a BeoLink 7000 RDS , special settings are needed to run it (two way communication) or just switch on it and everything is ok.
Thanks to all
You need to tell the Beolink 7000 which components you have in your Beosystem 7000, but that is it, it just works.. Go into Panel->Setup->System->Compnts
Be aware that there are a lot of Beolink 7000's where 2-way does not work anymore, but it is a quick fix, just replacing a few capasitors.... There are a lot of threads on Beoworld where this is described..
/Weebyx
Ok, so if it works regularly serves only to show the devices "Panel> Setup-> System-> Compnts" ....
Thanksl
