4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Razlaw:It does not on my BV7.
olvisab:According to you is it normal
This is normal.
When AST is on, every channel comes from all loudspeakers. The concept is that all loudspeakers are used to create a "virtual" loudspeaker for each input channel. However, although (for example) the centre channel is coming from all loudspeakers, it is doing so with different processing (including gain, delay and frequency response sculpting, to name the basic ones) applied to each loudspeaker. This is done for each input channel, so you can think of your system as a big NxM matrix where N is the number of input channels and M is the number of loudspeakers. For example, if you have a 5.1 input and 7 loudspeakers, then you have 6x7 = 42 different signals coming at you. . .
The effect vs. "price" comments you quoted from the earlier posting are still true, however. So, if you have well-placed loudspeakers AND you like precise imaging, you should turn AST off.
Cheers
-geoff
BTW: Happy new year everyone.
Geoff Martin:This is normal. When AST is on, every channel comes from all loudspeakers. The concept is that all loudspeakers are used to create a "virtual" loudspeaker for each input channel. However, although (for example) the centre channel is coming from all loudspeakers, it is doing so with different processing (including gain, delay and frequency response sculpting, to name the basic ones) applied to each loudspeaker. This is done for each input channel, so you can think of your system as a big NxM matrix where N is the number of input channels and M is the number of loudspeakers. For example, if you have a 5.1 input and 7 loudspeakers, then you have 6x7 = 42 different signals coming at you. . . The effect vs. "price" comments you quoted from the earlier posting are still true, however. So, if you have well-placed loudspeakers AND you like precise imaging, you should turn AST off. Cheers -geoff BTW: Happy new year everyone.
olvisab:This AST function is really great. I don't know if it is available on the bv 11 and avant, I hope so as it could be a real improvment in certain circumstances for all owners. But I wonder if this positiv effect is not completely lost if there is too much difference between the front and rear speakers, bl5 with bl6000 or 4000 for example.
The AST algorithm was not included in the new televisions since they have a new 16.5-channel upmixer instead. The effect is different, but the versatility is roughly equivalent.
An additional component of the AST algorithm is a correction filter applied to every loudspeaker that makes them more similar. As you know, it's madness to try to make a phantom image between two different loudspeaker models, so some corrective magnitude and phase equalisation had to be applied in the AST algorithm in order to get it to behave in loudspeaker configurations with more than one loudspeaker model.
Geoff Martin:The AST algorithm was not included in the new televisions since they have a new 16.5-channel upmixer instead. The effect is different, but the versatility is roughly equivalent. An additional component of the AST algorithm is a correction filter applied to every loudspeaker that makes them more similar. As you know, it's madness to try to make a phantom image between two different loudspeaker models, so some corrective magnitude and phase equalisation had to be applied in the AST algorithm in order to get it to behave in loudspeaker configurations with more than one loudspeaker model. Cheers -geoff
