Hello everybody,
I have a Beogram 1900, which runs still too slow after changing belt an cleaning everything. So I think I have to open the motor and clean and lubricate the bearings in vacuum. I did this with other motors before...but...in this case, I don't no how to get the Pulley and this copper reel off. Is there anybody, who can help me?
Thank you for answer. Andreas
Measure its position on the motor spindle first, so you can get it back in the same position,and then use a small puller.
Hello Martin,
thanks for response. A small puller...I didn't think of it...that's because I ask before.
Thank you very much an have a nice weekend.
Andreas
Quick Reply:
the small puller does its work. Motorbearings cleaned with aceton and lubricated in vacuum for 2 days with Velocite No 6 and all is fine. Full speed!!! Thank you.
