Beogram 9500 remote control does not work
This post has 3 Replies | 0 Followers
Esko Järvi
Finland
Posts 2
Esko Järvi Posted: Mon, Sep 28 2015 11:11 AM
I have been following this forum for a while and finally I have a real question:
I have Beomaster 4500, Beogram 9500 and Beolink 1000. BM 4500 works well with the remote control but BeoGram 9500 does not react to it at all.
While checking the Beograms service manual I noticed that the Data Link control comes with the BeoMasters RIAA amplifier to DIN connectors pin number 7 and without RIAA amplification to the pin 6. Would it work if I simply transfer the Data Link to pin number 7?
Esko
Dave Farr
France
Posts 2,283
Dave Farr replied on Mon, Sep 28 2015 11:23 AM
Hi Esko,
the Datalink should work with the pin in either position 6 or 7 according to past posts.  You can transfer the pin and see if it works though.  Don't lose the pin.  It's easy to do!  More often than not, the pins 6 and 7 are either both there are both missing.  If you only have 1 pin, try swapping it over.
Welcome to Beoworld by the way.
Dave.
leosgonewild
Helsinki, Finland
Posts 2,373
Have you modified anything of this, or are you using an external RIAA?
The BM4500 does not have RIAA, nor does the BG9500.
Esko Järvi
Finland
Posts 2
Thanks, Dave
The switch pin 6 and 7 together. Now works.
I use external RIAA pre-amp
Esko
Page 1 of 1 (4 items) | RSS
