Compatibility between MCP 6500 and Beosystem 7000
Jim8o8100
Posts 5
Jim8o8100 Posted: Sun, May 29 2016 10:05 PM
Apologies if this has been answered before, but I have a Beosystem 7000 and would like a remote with a bit more functionality than the Beolink100.
Ive had a bad experience with a Beolink 7000 that only had one way functionality, so wanted to know if the Master Control Panel from the 6500 series is compatible?
tournedos
Finland
Posts 7,357
tournedos replied on Mon, May 30 2016 8:11 AM
These are 100% compatible, but if a Beolink 7000 didn't work in two way mode, the fault may just as well be in your Beomaster.
EDIT: just to add: if the problem was "no contact" on the screen of the Beolink 7000 but it worked otherwise as a one-way remote, it is far more likely that the problem was in the Beolink.
--mika
Jim8o8100
Posts 5
Jim8o8100 replied on Mon, May 30 2016 7:39 PM
Thank you. Invaluable advice as always! The problem with the Beolink 7000 was indeed a 'no contact' error on the Beolink screen.
As with other buyers, I think I fell foul of someone selling something on eBay that they knew the value of, but not what it was actually meant to do!
Just need to find a 6500 unit for sale now!
Page 1 of 1 (3 items) | RSS
