Hi guys!
Bought a B14 which I hope will be suitable for my small apartment. But I am connecting them to a NAD C 510 DAC (hopefully a Beovision later on when the wallet allows it). Wondering if anyone knows if it is possible to get hold of some good cables for this? RJ45 to RCA. I got a very short one at the B&O store, but I would prefer not to have many adaptors on the way, one single cable would be nice. I ordered a 3 meter cable for soundsheavenly, but the connecters did not scream high quality.
Appriciate all answers =)
dj_ulf: Hi guys! Bought a B14 which I hope will be suitable for my small apartment. But I am connecting them to a NAD C 510 DAC (hopefully a Beovision later on when the wallet allows it). Wondering if anyone knows if it is possible to get hold of some good cables for this? RJ45 to RCA. I got a very short one at the B&O store, but I would prefer not to have many adaptors on the way, one single cable would be nice. I ordered a 3 meter cable for soundsheavenly, but the connecters did not scream high quality. Appriciate all answers =)
Welcome to Beoworld,
Steve at Sounds Heavenly produces high quality cables designed to fulfill the needs of the user as he understands B&O cabling requirements. Why do you say 'they don't scream high quality'? Have you used the cable? All cables I've received such as this have all been exceptional quality and have performed without fault as opposed to other 'cheaper' but supposedly 'correct' canbles from other sources.
Dave.
I also got 1 meter ones when i brought my beolab 14s from the store but they also ordered some 5 meter ones from soundsheavenly for me, and there is nothing to worry about interms of quality. They do the job perfectly and i haven't experienced any problems.
you will be fine.
Beoplay A2
