Hi.
I am trying to get the apple tv to work on the beo vision 7. The hdmi cable connects through the back of the tv and the picture quality is perfect. The problem is that I can not get any sound. I have done an update on the apple tv, and have looked at the settings on options but nothing seems to help.
If going to the configuration for av1 I can set the output to hdmi, then a list of all different boxes appear. Which one on here should I select? I usually go on sky digital.
Any help would be appreciated. This also seems to be a problem on all stuff that I connect through the hdmi cable.
gareth8777:Hi. I am trying to get the apple tv to work on the beo vision 7. The hdmi cable connects through the back of the tv and the picture quality is perfect. The problem is that I can not get any sound. I have done an update on the apple tv, and have looked at the settings on options but nothing seems to help. If going to the configuration for av1 I can set the output to hdmi, then a list of all different boxes appear. Which one on here should I select? I usually go on sky digital. Any help would be appreciated. This also seems to be a problem on all stuff that I connect through the hdmi cable. Thanks
I have a similar issue and solved it exactly as you suggested. However, I always thought that this indeed have limited me to stereo. I know that the BV can still put out something with 5.1 speakers, but that woudl not be the original 5.1 track from the movie (as this has been removed to stereo while transmitting)? Any ideas?
Any thoughts?
