Essence remote IR beam
js
Posts 382
js Posted: Wed, Jan 21 2015 2:08 PM
As the Essence remote can be configured to send IR commands, I am considering installing one on the wall to control the volume of one of my IR-based setups.
In order to define the best position of the Essence remote on the wall, do you know where the IR beamer is positioned in the remote and in which direction(s) it is beaming?
Many thanks  Smile
BeoMegaMan
Posts 601
There are 4 IR's placed two on each side. One closer to the top, the other closer to the bottom.
Ah, you know... A little B&O here, a little there
js
Posts 382
js replied on Wed, Jan 21 2015 8:08 PM
Thanks  Smile
Page 1 of 1 (3 items) | RSS
