MLGW and Somfy Blinds transmitter
This post has 15 Replies | 1 Follower
7corona
Posts 12
7corona Posted: Wed, Jan 14 2015 9:28 AM
Hi, I have recently bought a second hand Master Link Gateway mkII and I'm looking at blind options. Clearly the Lutron Blinds are a known working option, but extensive so I am looking at the Somfy blinds. These blinds have an optional RTS Transmitter that can be feed from a home automation system. Does anyone have any previous experience of interfacing the MLGW with the RTS transmitter with success?
http://controlissblinds.co.uk/rs485-rts-transmitter
Many thanks
beoandy
sissi not kangaroo
Posts 329
beoandy replied on Wed, Jan 14 2015 10:07 AM
hi corona!
look to the lintronic TT455-RT-238 on http://lintronic.dk. you can control the lintronic box via rs232 with custom strings. maybe lintronik can control the somfy transmitter?
BS Ouverture, BS 9000, AV 9000, Avant 32 DVD, BV9, BV6-22, BS 5, BS 4500, BS 7000, BC 9500, Beo6, BL Penta, F1000, BLGW, etc....
StUrrock
Posts 995
StUrrock replied on Wed, Jan 14 2015 12:08 PM
we have in the past sent rs232 signals from the MLGW to an elang or RTI processor which then communicated to the somfy via rs485
just remember the somfy has a weird numbering system for the rooms
room number - 1 = number to put in somfy rs485 code creator software
Steven_London
Posts 51
I had the same issue with Somfy blinds and controlling them using the Beolink Gateway. I found this online and thought I would give it it try because it was significantly cheaper than the Somfy RTS transmitter.
http://www.uk-automation.co.uk/products/RFXCOM-RFXtrx433E.html
I worked very well with the enclosed software but I could not get it to work at all with the BLGW, maybe a better person than me may be able to reverse engineer the commands that the software sends the transmitter. As a solution I added the RFX transmitter to a Raspberry Pi and used that as a bridge, so the gateway talks to the Pi and the Pi sends the commands to the Somfy via the RFX transmitter. It works perfectly and cheaper than the Somfy 485 transmitter.
7corona
Posts 12
7corona replied on Mon, Jan 19 2015 1:09 PM
Many thanks, this looks like a potential solution.
7corona
Posts 12
7corona replied on Mon, Jan 19 2015 1:10 PM
Thanks, I will look into this and report back
tompa
Posts 64
tompa replied on Fri, Jan 23 2015 1:02 PM
I have used mlgw and connect to somfy rts transmitter thru rs232 and used customstring so it works
7corona
Posts 12
7corona replied on Fri, Jan 23 2015 3:17 PM
Hi, thanks for this, question if I may (I'm not that technical), how did you wire the RS232 to the TRS transmitter?
mjmedlo
Posts 922
mjmedlo replied on Sat, Jan 24 2015 12:25 PM
Tompa,
Can you elaborate?
tompa:
Steven_London
Posts 51
I know in the US market they make a RTS RS232 compatible controller, but for some reason in Europe only the RS485 is available.
tompa
Posts 64
tompa replied on Mon, Jan 26 2015 9:54 PM
It's some years ago but for the Cable i remember i solder a simple  1 wire txd mlgw  to  rxd somfy rts and 1 wire gnd thats it
i see if i had the programming for the customstring on mlgw and get back
tompa
Posts 64
tompa replied on Mon, Jan 26 2015 10:21 PM
I don't notice that problem iwas rs485 on european rts,   this was some years ago and i use a US model with rs232 but maybe it's possible to use  rs232 -> rs 485 converter maybe? or buy US model because RTS transmitter use 433,92 mhz in US also i not sure now but probebly the same
mjmedlo
Posts 922
mjmedlo replied on Tue, Jan 27 2015 1:44 AM
@tompa. If you could just give an example of the custom strings that would be great.
Thanks I. Advance
tompa
Posts 64
tompa replied on Tue, Jan 27 2015 9:11 PM
You only type in for example  0103U   in match/command field in mlgw  =  RTS adress 1  motorchannel  03 (1-16)  and motor UP
or                                            0103S   in match/command field in mlgw  =  RTS adress 1  motorchannel 03  (1-16) and motor stop
or                                            0103D   in match/command field in mlgw  =  RTS adress 1  motorchannel 03 (1-16) and motor down
all as output command in type field in mlgw
/Tompa
mjmedlo
Posts 922
mjmedlo replied on Wed, Jan 28 2015 2:56 AM
Great!
Thanks for this.
Was this done based upon the rs232 commands.
tompa
Posts 64
tompa replied on Wed, Jan 28 2015 6:22 AM
yes rs232
and i wrote wrong in earlier post (433,92Mhz )but somfy use 433,42Mhz but it's the same in US and EU so it would be no problem to use the RTS universal interface II  US model in europé (and that was the interface i used)
/Tompa
Page 1 of 1 (16 items) | RSS
