So one of the channels is working just fine, the other I measure 0mv, is the potentiometer dead or should I check for anything else too?
Also the base of both ic200 and ic201 is about 0.1v which is too low compared to ic100 ad ic101 which is about 1.1v
edit2: between diods d203 and d201 there should be about 1.7 v, which i got in the working channel but only about half of it on the non working side
Yiangos
Soldering on the output transistors, solved:) Thank you Martin
[please delete]
