Sorry if this has been covered - but I cant seem to find the Beoplayer App any more - I have it on my iPhone and wanted to install it on an old iPad that will be used just for music - but it's not there. Have B&O withdrawn it? Shame as the radio section was really good
You can't buy it anymore - it has been discontinued.
But if you once have had it, it should still be in 'the cloud'.
Assuming that you use the same account on both devices, you should be able to find it under 'my purchases' in the app store/the small cloud symbol with the downwards arrow.
And - yes, this has been covered before on the forum
Hi Andrew,
It has indeed however your iPhone version should work for your iPad - maybe the sizing will be tiny though. The app will still be in your account, so jut redownload :) I tend you use TuneIn now as it features every radio station more or less throughout the world :)
But the BeoPlayer was nice.
I have always wished for an iPad version of it.
Hi thanks, yes I did purchase it - just taken a look in purchased under apps store and realised I was looking at iPad purchases - now have it back on my iPad - thanks guys - really pleased to have it back.
Nice one Andrew! Hang on to it! Thanks MM also :)
