I have a beosystem 3 working with a beovison 4-50. I wanted to know if there is a way of forcing the system to start (image on screen) more quickly. This has more recently become a frustration as I have a SKY HD signal that has been split and sent down a long HDMI cable before connection to the beosystem 3, and you almost have to force the set by switching between TV/DVD/DTV sources before it will realise there is a signal there (via the DTV/HDMI A)! The slow start happens no matter what source you select initially.
Any thoughts?
