If you own the new Avant, what, if any, settings have you tweaked?
I've read somewhere about turning judder off. Have you done this or tweaked other values?
So far I've turned the backlight down slightly, judder off and colour up slightly. Do you have any recommended settings? Any advice is good!
The picture I've got is fantastic, but I'm no expert and if i can make it even better, then I'd love to try it.
Dave
http://archivedforum2.beoworld.org/forums/t/3372.aspx?PageIndex=1
Here is the full review and calibration for the Avant that FlatpanelsHD did. http://www.flatpanelshd.com/review.php?subaction=showfull&id=1408435339
I was not impressed at all with my Avant's picture quality out of the box. I found it cold and very bad at handling fast movement or panning. The Judder reduction, noise reduction and all that stuff actually made the picture worse. When I used the FlatpanelsHD calibration, I notice a marked improvement. So give it a go. The main thing is that you're happy with the picture.
KMA
B&O product history since 1991: Ridiculously long to list in a signature.
i've followed the flatpanelHD calibration settings, with the exception of TV mode, where i've set the sharpness to 12, as most channels are SD and i felt this looked a bit soft.
The picture is now very good indeed.
You're right about your eyes going a bit nuts when you keep changing the settings though, it's difficult to know whats looking good and what isn't. Wish i'd just followed the calibrated settings from the start.
Cheers all!
