Which Power Supply for on-board beovision 3 amplifier circuit
Michel
Alkmaar
Posts 26
Michel Posted: Fri, Feb 20 2015 5:06 PM
Hey all,
I'm currently trying to use the built-in speakers as external speakers which i would like to connect to my pc.
I already had a look into the service manual of the beovision 3. All I can see is that I need a -20 and + 20 volt for the amplifier-board on p58 (1.2.) and then right channel, gnd, mute (6v), left channel on p57 (1.2.3.4.)
Is it possible to use a laptop power supply with 20V output? Do I have to make sure it is a certain Ampere and Watt (Volt x ampere)
Thanks for your help!
With regards,
Michel
Page 1 of 1 (1 items) | RSS
