Hi there, I have a question about my grandfathers old Beogram RX which is running slow.When i play a record, the sound when somebody sings is very deep and slow.I have replaced the rubber band and i have also cleaned it inside, but it still sounds terrible.It hasn't been used in a very long time, so i made it run for three hours, but that did not make any difference.I would be very happy for any useful answer.
Thank you in Advance Yoel
Hi Yoel,
I have the same problem!
Did you ever solve?
Al
Yes, I went to a turntable repair guy. He said that underneath the turntable, you could adjust the speed.It was pretty simple (he said).
