V1 additional speakers question
This post has 1 Reply | 0 Followers
Razlaw
Posts 4,345
Razlaw Posted: Sat, Feb 21 2015 8:35 PM
Sorry to ask what is probably a dumb question, but I can't figure it out. I connected a pair of Beolabs to my V1, I want to have just the V1 speakers on when watching TV, and just the Beolabs when listening to music. I have set up the two speaker groups and they work fine.  I can switch between the groups using the Beo 4. What I can not due is save the audio speaker group such that when I switch to an audio source it will automatically switch to the proper speaker group.  The user guide says this setting can be made in the "advanced" settings menu under sources setup. I can not find that menu.  What are the steps to get to the appropriate menu to save speaker groups to certain sources?  Thanks!
Razlaw
Posts 4,345
Razlaw replied on Sat, Feb 21 2015 10:10 PM
Problem solved. Found the right menu.
Page 1 of 1 (2 items) | RSS
