Beovision 8-32 - stand questions
This post has 3 Replies | 0 Followers
Andrew
Frinton, UK
Posts 917
Andrew Posted: Mon, Feb 16 2015 4:28 PM
Is there a special table top stand for a Beovision 8-32, I ask because I have taken mine off it's stand to sit on a cabinet but obviously the subwoofer is muffled and worried that it may fall over so may put it back on teh stand - or can you put rubber feet underneath it?
Also if anyone has one and wants to swap it for a floor stand then that would be even better
Millemissen
Flensborg, Denmark
Posts 14,680
You normally get a set of 'feets', when you buy the BV8.
Using these you can adjust the angle of the screen......and they elevates the speaker in order to let the 'bass breathe'.
If you have the original box, they might still be in it.
Otherweise try contacting LifeStyleAV - link above!
Secondlife
Posts 145
Give me a PM and I will ship you a pair. No charge.
billymartin
Posts 3
Do you happen to have any more of these? I'd gladly buy them from you
Page 1 of 1 (4 items) | RSS
