Hi
I have a problem which I couldn't solve by finding it on the forum.
I have a beolink aktiv and a bv8-40 in the same room, it's a linkroom.
I set up the beolink in option 4 and the bv8 in option 6
Now when I start the TV everything is fine the Aktiv isn't power up, but if i press link an for example radio the tv and the beolink are powering up???
shouldn't by pressing link the ir codes only control the beolink aktiv
should i try a different setting ?
regards George
Set BV to V.OPT 5 and BL active L.OPT 4 or both to OPT 5.
Stefan
