I have noticed a very faint hum when my Beolit 12 is turned on.
The hum is there wether airplay is on or off.
Does anyone else experience this?
yes .But as I've said in another post its gone back to B&O now. the white noise was a little irritating next to my ear throughout the night as we used it for netradio at night. Will the A9 be better?
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
Not really. Id not thought about it too much . However, it never did airplay for us and was hard wired ,which was not good. When the catch on the side door failed that was too much though.
Mine hummed from day 1, silent, but audible when not playing music, or at the lowest possible volume setting. I can hear it from a few meters away, if it's really silent at home.
I did not find it to be a big issue. Mostly, when the beolit is on, it is playing music, otherwise I shut it down.
Beolit 12 - Beolab 4 pc (dead now) - Beoplay H5 - Beolab 9 - BeoRemote One BT - Beoplay M3
well it's more hissing than humming actually...
crossbytje: well it's more hissing than humming actually...
"White noise" ?
This is what it sounds like
http://youtu.be/Fw349eI1SQ4
-edit-
I've had three different BeoLit 12, all makes that noise. It´s audible from about two meters distance easily if you sit in ear height against the tweeters. It is a common sound on amplified speakers. Some are louder than others.
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
BeoBoy68:Not normal Noise ! Ask this man to refund your Money or Exchange your product !
StUrrock: BeoBoy68: Not normal Noise ! Ask this man to refund your Money or Exchange your product ! Best post on BeoWorld EVER
Not normal Noise !
I got a refund at the weekend as it's obsolete now.
