US Beosystem 3 in EU?
lano
Posts 161
lano Posted: Fri, Mar 6 2015 6:33 PM
Will a U.S. Beosystem 3 work with in EU (PAL/NTSC)?
- Internal DVB receiver (if exchanged for a EU type)?
- External devices connected through HDMI?
I know that I will need an adapter for the voltage conversion.
Regards lano
Radiomekaniker
Posts 49
Hi the mains supply can be fixed by making sure that jumper P400 on the power supply pcb is mounted correctly, in countries where mains is 110V mount the jumper. Otherwise not. You can remove it.
HDMI is HDMI eu/us no change.
It should be possible to build in DVB in it, but I would use a external box and control it with the B&o remote via the PUC feature.
Page 1 of 1 (2 items) | RSS
