Beolab Penta II Bass Extension Switch "broken"
Lennart25
Germany
Posts 46
Lennart25 Posted: Fri, Mar 13 2015 5:58 PM
Hello everyone,
one of my beloved Pentas has a small issue, which is that the small switch for the bass extension is loose and seems to not change the state of the actual setting - you have no resistance as usual and as the other switches have. Does anyone know how to remove the plastic cover and/or fix my problem in a different way ? Since I want to place the speakers in a different space it would be quite good if I could change the setting at least manually.
I appreciate any help :)
greets from Lennart
parasound
Sweden
Posts 69
parasound replied on Fri, Mar 13 2015 6:56 PM
Hello!
A few years ago (5-6) the same happened to me.
Just went to a Bang & Olufsen store and order it from them.
Don't now if they still have them at stock, if you lucky they might :)
Living room: BeoVision 4-50 ACM, Beosystem 3 MK3 with samsung SP-H710AE projector, BeoLab 7-1, BeoLab 6000x3pair, BeoSound 3200, AV & CD cabinett & Beo4.
Lounge: BeoSound 3, BeoVision 7-32 mk5 & Beo4
Kitchen: BeoLab 2000 & Beo4
Master bedroom: BeoVision Avant-32, DVD1, BeoSound Ouverture & Beo4
Guest room: BeoVision 4002, DVD1, BeoSound 2000 & Beo4
Lennart25
Germany
Posts 46
Lennart25 replied on Fri, Mar 13 2015 8:20 PM
Thank you for the fast answer - do you know how much it costed ?
parasound
Sweden
Posts 69
parasound replied on Fri, Mar 13 2015 10:43 PM
Dont really remember.
Around 6-9 euro
Page 1 of 1 (4 items) | RSS
