Beovision 8 masterlink socket.
offmied
Posts 2
offmied Posted: Wed, Jan 14 2015 9:49 PM
Hi all, I am new to the forum as I have never had a problem before. I have a second Beovision 8-32 that I have just fitted with the freeveiw module but I cannot get the masterlink socket to connect my Beosound overture. Does anyone know what the settings  are in the onscreen menu please.
Millemissen
Flensborg, Denmark
Posts 14,680
Does it have the MasterLink module built in?
offmied
Posts 2
offmied replied on Wed, Jan 14 2015 10:15 PM
That could well answer my question, my original 8-32 was ordered new & B&O set it up for me. I now presume that my 2nd set hasn't got a ML module, are they still available?
elephant
AU
Posts 8,219
elephant replied on Thu, Jan 15 2015 1:20 AM
I am sure a call to a dealer will get you one.
But there may be cheaper integration approaches.
What sources are youu wanting to access across the ML ?
BeoNut since '75
tompa
Posts 64
tompa replied on Fri, Jan 23 2015 1:10 PM
If i understand you right you have the ML socket on your bv8-32 ? if so you also have ML module,  but you maybe have to set v.option 2 on tv (default is v.option 1 and then tv is not listen to audio commands from remote)
coolpix
Posts 18
coolpix replied on Tue, Nov 24 2015 1:28 PM
Hello, i need a module ML for my beovision 8 32. Do you have ? Thx
CasperIDK
Denmark
Posts 5
CasperIDK replied on Tue, Nov 24 2015 7:35 PM
In order for the Ml module to be active, you will have to disable the power saving function in the TV.
That might be the reason it isn't working
:: Love Affair :: BeoVision 11-46 :: BeoLab 18 :: BeoLab 19 ::
Page 1 of 1 (7 items) | RSS
