I am new on the forum and an absolute beginner in the B&O world.
Can I connect an IPhone on a Beosound 4 or a Beosound 3200 ???
Many thanks for your answers.
Roby
Roby,
welcome to Beoworld. According to the specs on the products section, both have AUX inputs which you can use. You just need the correct cable to plug into the AUX sockets and a 3.5mm jack for your iPhone. Steve ate sounds Heavenly sells them from the banner below.
Dave.
You could also buy an airport express (assuming you have wifi), connect it to the aux input using the same cable, and then stream your music via airplay.
Welcome to the forum.
I am doing exactly what Stan said with my Beocenter 8500 and I couldn't be happier. Streaming TuneIn radio and Deezer music and it works great.
Hi Dave, hi Stan,
Thanks so much for your thorough answers that will be very useful.
I have another question for you : I have a pair of vintage speakers Beovox S45. Do you think I can keep and use them with a Beosound 4 or Beosound 3200 or is it worthy to invest into more recent speakers in order to get the best from the hifi system ?
Many thanks for your tips.
my very Best,
