http://www.ebay.co.uk/itm/BANG-AND-OLUFSEN-COMPATIBLE-BLUETOOTH-AUDIO-RECEIVER-REF-BLUETOOTH-/221706986016?pt=LH_DefaultDomain_3&hash=item339ec42220
If I buy one of these (above), can I plug it into the back of my beo center 2300 and will it then give it wireless capability so I can connect (wirelessly) to a BeoLab 3500 Main / Stereo Speaker?
I am not technical, I am just a music fan with ears that need perfection! thank you
No - is the short aswer....sorry!
It is a receiver - you can send audio wirelessly from a bluetooth enabled device (such as a smartphone) in order to hear it through the audiosystem (your BC2300/connected speakers).
The BL3500 is a link room speaker.
You'll need a MasterLink (wired) connection to hear anything through that (this requires a ML/MCL Converter for the BC2300).
Or you will need the B&O BeoLink Wireless1 solution:
http://www.beoworld.org/prod_details.asp?pid=1028
