Beosound 8 Airplay faking :)
This post has 3 Replies | 2 Followers
Lanny
Czech Republic
Posts 9
Lanny Posted: Sat, Jun 23 2012 9:42 AM
I was upset that I could not use Airplay and I am not about to upgrade the the new deosound just to get it so this is what I did do:
I bought a BT mini receiver (about  $20), plugged it in the BS 8  and voila, I have Airplay. Well almost.  It plays well to about 5m.
ONG_SOON_HUA
Posts 4
This is great! Are you using a 30 pins BT receiver? What is the brand? I've already tried 2 types in the market but just couldn't found work with my Beosound 8.
Millemissen
Flensborg, Denmark
Posts 14,680
If money saving is not the biggest part of your 'upgrading' troubles, buy a (second hand) Playmaker.
Plug that (using PL-out via adapter and the PM in fixed line-out) into the line-in of the BS8.
Then you have real AirPlay and a free autosense line-in connection (on the Playmaker) as well.
jk1002
Posts 278
jk1002 replied on Sun, Feb 28 2016 10:42 PM
Yeah. Or use an Airport Express which also would support later gen wifi standards that work generally better in urban settings with wifi congestion.
Bluetooth is a bit sound quality degrading.
Cheers
JK
Page 1 of 1 (4 items) | RSS
