Hi all,
I've just discovered a small red toothed wheel on the back of the front control panel on my Beogram. It is just to the left of the stop button, but as I say out of sight behind the panel. Had this deck over a year and never noticed this before! What does it do? I guess some sort of adjustment to either the arm or the speed. Haven't tried it yet, thought I would ask you good people first.
Thanks,
Graeme.
It's the pitch control wheel.
Dave.
Not immediately obvious, is it! I didn't notice one on mine for years either!!
Peter
I only noticed it by chance as I was giving the deck a quick clean. Haven't needed to alter the speed - yet - but handy to know anyway.
Peter: Not immediately obvious, is it! I didn't notice one on mine for years either!!
It's in the user manual but not many people have the manual with the TT. I didn't notice it until I put mine on a higher shelf. Obvious really as all TT's need to have a control somewhere to do this. Sometimes it's just a case of finding it! According to the manual it's 'illuminated' but I haven't noticed on mine.
It has a dial, showing 0, +/-1,2,3 etc... on the panel right in front of the red wheel.If you don't see it, the lamp is out.
Dillen: It has a dial, showing 0, +/-1,2,3 etc... on the panel right in front of the red wheel.If you don't see it, the lamp is out. Martin
Also as it's not plugged into the mains at the moment either!
