I have a question regarding my setup. I have done everything correctly as far as I know, but I am just looking for some clarification with how to best use my receiver with the 4.1 system I have. The receiver I am using is the Yamaha RX-V775. I am using the A/V multilink cable and plugging directly into the SPEAKERS section of the receiver (by means of the standard exposed wire - the far right side of the attached picture) and I have them plugged into the Front (R and L) and the Surround (R and L) accordingly.
The system (obviously) sounds amazing, but I currently have the sound mode on 7.1 surround which to me sounds perfect, but I am wondering if I should instead be using a different mode or potentially set up a custom one? (As far as I can tell I cannot find a 5.1 setup anywhere on the receiver - only 2.1 and 7.1).
The last thing I was seeking some clarity on was the LFE 0 + 10dB switch on the base of the subwoofer. Is this intended to be switched on when using a non-B&O television, or does it not make a difference either way if I have it on or off? Thank you very much for your help and if there is any clarity I need to give, please just tell me!
http://img1.lesnumeriques.com/produits/490/15711/512b40ab5f779.jpg
