Dear members,
I think one of the powerlink sockets on my Beosound 2500 is introducing a hum on my Beolab 3s. Initially I thought it was due to the cables or the Lab 3s but it seems to be the socket. I use MK 3 Powerlink cables and when switching sockets the humming moves from one speaker to the other independently of the cables...
Any ideas?
Cheers,
Kai
Well, once you've ruled out the cables...let me think. One thing to try is a splitter, you don't need to connect to each PL output since they both carry L and R signals, you can get a splitter and split the signal at the good connector and run to L and R from there.
Cheaper and easier than a fix of the unit, unless the problem is in the L or R signal from the master, but if you've swapped cables and it didn't occur that shouldn't be the issue.
Jeff
Thanks Jeff,
that's good advice. I wasn't aware of the splitter possibility. Maybe it's only an issue with the Beolab 3s? However, it's a strange one...
Greetings,
