Just switched on my Beosound 9000 this morning and the link system seems to have died...
I have a Beovision 7-40, Beosound 9000, Avant rf 28 and a Masterlink TV all connected via a Masterlink junction box.
Current system has been working together for some years and has now suddenly stopped talking to each other.
All the bits work independently but with the speakers on the Beovision there is no sound for the CD, no dvd for the bedroom..
Any suggestions on possible solutions?
Eclipse 65V1-32Beosound M5Essence MK2BLI
Thank you for the quick reply.
Have tried the power down option on everything.
As far as options go the system was set up by my local dealer and he did not share them with me.
On reading i think in the main room I should set the Beovision 1 to v opt 2 and the Beosound to A opt 0. Not sure about the other TV's in link rooms though? Assume still v .opt 2?
Thnaks again
Have tried resetting options but nothing working.
Is there a way of checking that the Master Link connections are actually working?
Thanks for the suggestion.
I tried this but still no luck but I was sitting in the room with the link TV and in frustration switched it between analogue and digital very quickly a few times. Suddenly the digital from the main Beovision appeared for 5 seconds then went again. I could not replicate this but have checked frequencies in case this was the problem.
Generally speaking nothing can make the main Beovision 1 react to the linked equipment. The BV1 works OK by itself and correctly fires up all the attached speakers - 2 8000's, 2 6000's, a Beolab 2 and a centre 7-4.
johnheartfield:Just switched on my Beosound 9000 this morning and the link system seems to have died... I have a Beovision 7-40, Beosound 9000, Avant rf 28 and a Masterlink TV all connected via a Masterlink junction box. Current system has been working together for some years and has now suddenly stopped talking to each other. All the bits work independently but with the speakers on the Beovision there is no sound for the CD, no dvd for the bedroom.. Any suggestions on possible solutions?
Well that worked๐๐๐
The 9000 and the 7-40 now working.
Thank you very much. I will leave everything else disconnected until you get back to me
Thanks again for your help
johnheartfield:Well that worked๐๐๐The 9000 and the 7-40 now working.Thank you very much. I will leave everything else disconnected until you get back to meThanks again for your help
Those old avants are very heavy...
Done that and nothing else yet - you are my guru
All done as told. Seems to be all systems go now.
Thanks very much for the help.
In slightly cold Derbyshire, England so a hot sweet tea and a quick rub down with the Financial Times.
Great thanks again to you and Seanie_230
