Hi.
Just bought myself a TX2 which was functioning just until the arm had to return after playing the first half of the record.
Now it's stuck and I don't know what to do.
Anybody know if this is a known issue and what the fix is?
While it's torn apart is there anything worth servicing? Since I in that case might as well take my precautions.
I am in correspondence with the seller regarding this too.
Thanks.
Regards Frederik
Hi Fred
Maybe you have a closer look to this:
https://archivedforum2.beoworld.org/forums/t/29552.aspx
and this:
https://archivedforum2.beoworld.org/forums/t/40664.aspx
Good luck and regards
Christian
