Dear members,
I have a special masterlink cable with three plugs. One on the one end and two on the other. In the middle there is some sort of splitter. What is this type of cable for?
Greetings,
Kai
Without seeing the actual cable you have, it appears you have a basic masterlink cable for use with three products. Someone has basically used a masterlink junction box, to /connect/split a cable so it has three ends.
Thanks very much. I think this is already the answer I was looking for! Cheers, Kai
