New house with B & O ---- Need help
This post has 13 Replies | 1 Follower
Dravin
Posts 7
Dravin Posted: Mon, May 4 2015 3:25 PM
So I recently moved into a new house where they had some speakers and wall controls pre-installed throughout the house as well as a passive link in another room.  I found the masterlink cable connected to the Beolink Passive and tracked it through the walls where it actually went to the entertainment center.  This cable is just cut right there at the entertainment center.
What do I need to get this system up and operational?  I'm trying to connect my TV to the surround system but I don't know what is all needed.
Hiort
Sweden
Posts 2,895
Hiort replied on Mon, May 4 2015 3:32 PM
What TV do you have and what speakers are installed in the house?
Dravin
Posts 7
Dravin replied on Mon, May 4 2015 3:35 PM
I just have a Samsung 52" flat panel TV.  Model is LNT5265FX/XAA.  I'm not sure of the exact speaker models because they are mounted in the wall but none of the speakers are free standing and they are all B & O
jowus
Posts 161
jowus replied on Mon, May 4 2015 3:41 PM
You're Lucky Buyer, you can just go to B&O website to find out what Speakers they are. I don't think anybody can help you without knowing the Speakers you've in the House. Good Luck.
Dravin
Posts 7
Dravin replied on Mon, May 4 2015 3:49 PM
I'm not sure why the speakers would actually matter since they connect to the Beolink Passive no?  2 of the speakers appear to be BeoLab 4000 speakers from what I can tell.
Dravin
Posts 7
Millemissen
Flensborg, Denmark
Posts 14,680
Could you provide more details?
Can you localize all the cables for these speakers/where are they/do they all run from one place (...'to the entertainment center').
If possible, please post some pics of what you have/you see.
Dravin
Posts 7
Dravin replied on Mon, May 4 2015 4:14 PM
Only 1 cable (the masterlink cable) runs down to the entertainment center).  All the other wires run through the walls and appear to go up to the Beolink Passive which is in my master bedroom.
kallasr
Germany
Posts 2,562
kallasr replied on Mon, May 4 2015 4:50 PM
So a masterlink audio system would be enough to bring audio to all the speakers, use the aux in if you wish to connect your tv to system.
Dravin
Posts 7
Dravin replied on Mon, May 4 2015 5:13 PM
Thank you for that.  That helps a lot.  What do I do with the cut masterlink cable?  Do they sell a junction box and masterlink cable to be able to attach a new end to the existing cable?
Dravin
Posts 7
Seanie_230
UK
Posts 2,278
Hi there
You can buy master link junction boxes take a look on eBay or Steve from sounds heavenly.
Cheers
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
StUrrock
Posts 995
Seanie_230:
Hi there
Cheers
BLGW - Rekindling the love of ML
Or even maybe, God forbid, a B&O dealer who could also provide professional advice for your situation.
Smile
Amazone
Netherlands
Posts 187
Amazone replied on Mon, May 4 2015 9:36 PM
Smile
Agree. Possibly the nearest dealer knows all details because he installed it. Much better then us guessing without having any info at all. Just visit a dealer and request advice.
BeoVision 11-55, BeoLab 8000, BeoRemote One BT, AppleTV 4, 2x BeoPlay A2, BeoPlay A1
Page 1 of 1 (14 items) | RSS
