I just purchased a set of Beolab 8000 active speakers and would like some advice on which B&O system to connect them to.....thoughts???
Hi.
Do you already own any other B&O equipment , particularly something with power link connections? Most B&O kit from the early 90,s onwards have this including, as Chris says, the televisions. If not you will need an amplifier with with pre amp line out connections. Did the speakers come with cables? You need either power link cables for B&O kit or line signal cable for non B&O. Recommend you contact Sounds Heavenly on this site for further advice regarding cables. I expect you have already noticed the switch at the back of the speakers to select left, right or line signal.
Graeme.
