Beocom 6000 battery - Details needed to order the correct battery
This post has 3 Replies | 0 Followers
beoaus
Posts 177
beoaus Posted: Wed, May 6 2015 2:41 AM
Hi All,
Have a couple of Beocom 6000's that need new batteries. How do I find model or details needed to order the correct batteries?
I think when you get the batteries there is process need for the phone to recognise them so I would need that as well.
Thanks beoaus.
Andrew
Frinton, UK
Posts 917
Andrew replied on Wed, May 6 2015 10:57 AM
Hi, I just ordered one from amazon and it did the job - put it in the phone and let it charge overnight and my beocom 6000 has been fine ever since - here is a link
http://www.amazon.co.uk/gp/product/B002MPYM3W?psc=1&redirect=true&ref_=oh_aui_detailpage_o07_s00
It's worth a shot at less than £6!
beoaus
Posts 177
beoaus replied on Thu, May 7 2015 6:17 AM
There are a few type of batteries and it takes weeks to get batteries here. Also have 5 phones in all to get sorted.
Andrew
Frinton, UK
Posts 917
Andrew replied on Thu, May 7 2015 8:49 AM
the phone I used the battery in is used occasionally but it did fix the problem, I have did once buy one and it didn't fit properly. I would order one and see how that goes. I don't use my landline much so it may be a different story if you use it a lot.
Page 1 of 1 (4 items) | RSS
